THrottle temp sensor and engine harness ground
Old 02-08-2003, 12:32 PM
lonefuzzy79's Avatar
Default THrottle temp sensor and engine harness ground
I am wiring in my 4 wire O2 sensor and I need to know which wire to wire to and where the Air intake sensor is located, there are several good candidates. The other question is that one of the black wires needs to go to ground. Where does the engine harness ground out? Thanks
Old 02-08-2003, 04:33 PM
Default Re: THrottle temp sensor and engine harness ground (lonefuzzy79)
ttt
Old 02-09-2003, 01:00 AM
this is on a D16Z6 dropped into a 95 CX
Old 02-09-2003, 01:13 AM
EK MONEY's Avatar
the engine harness grounds on the block where the lower radiator hose connects to the engine. The intake temp sense is a white plug on the front and top of the intake manifold. as for the O2, just go color to color and youll be ok..
Old 02-09-2003, 01:20 AM
GTlvr82's Avatar
Default Re: THrottle temp sensor and engine harness ground (Peagreenhatch)
what he said
dog2525
07-08-2009 09:00 AM
beaterman
06-11-2008 10:21 AM
Slick2126
03-18-2006 04:50 AM
k7q
03-09-2006 09:45 PM
DevineCRX
07-18-2002 07:31 AM
Quick Reply: THrottle temp sensor and engine harness ground
