throttle crazy when car not moving.
When I am in neutral and try to keep the RPMS steady at 2500 it will either bounc up and down aroun 1400-1900 or if i hit it a little harder it jumps to 3100+ it doesnt do it while driving obviously, any ideas on what to do?
maybe your tps(throttle positioning sensor) is broken.
Re: (2FAST4U831)
or check your vaccum lines or your IAC valve
Check TPS.
Check IACV. |
Re: throttle crazy when car not moving. (mongoliandonuts)
TPS Sensor sounds bad https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (JDMFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">or check your vaccum lines or your IAC valve</TD></TR></TABLE>
correct me if im wrong, but there is only coolant lines running to the IACV. |
Re: (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">
correct me if im wrong, but there is only coolant lines running to the IACV.</TD></TR></TABLE> true but it also send a signal to the ecu to open and close coolent for the throttle body... i just read it on my cheap autozone book, becuz i just recently fixed mine becuz it was dirty... |
Re: (JDMFreak)
true but it also send a signal to the ecu to open and close coolent for the throttle body...</TD></TR></TABLE> did it fix your problem? because im having the same problem. what did you use to clean it? |
