Throttle Body Replacement
Replacing my d series throttle body with a b16 throttle body. Do i need a new gasket? do i need to port match the intake mani and do i need to take the tps of my current throttle body?
Re: Throttle Body Replacement
get a new gasket...they are like less than $5 im pretty sure. and it would help performance but isnt required. and the new throttle body should have a tps. if you do swap tps sensors, then make sure you get it installed correctly.
So if i dont port match it it basically will do nothing right?
if you port match it it will get more air into the intake manifold...it will help but you dont have to do it.
Ok thanks for the help
What do i do about all the extra vacuum lines and the map sensor???
gasket from honda is $8, shouldnt have any extra hoses
