throttle body question
I need a throttle body for a b16a2 badly!!! does anyone know if a gsr 58mm will do the trick, and does it have the same tps/map sensor and that?
thanks
thanks
if you use the gsr tb, you will need to swap the throttle cable pulleys, since the gsr operates differently from everything else
very easy to do
aside from the pulley, gsr and b16 tb's are the same
very easy to do
Re: (krout206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krout206 »</TD></TR><TR><TD CLASS="quote">^^^What he said....by the way i think all integra throttle bodies are 60mm </TD></TR></TABLE> itr is 62mm
projecthybrid04
10-07-2003 10:13 AM
