THROTTLE BODY
THROTTLE BODY
I hve read lots about them but what one should i fit to a 95 D16Z6 engine and what will i have to change to make it all work (map sensor).
Re: THROTTLE BODY (gavhowe)
get any 92-5 b-series or h-series (h22a) throttle body, they should all bolt up some newer ones (94-5) come with Map sensor on top of TB, but they are not neccessary as you can get one off a DX that monunts on the firewall
Re: THROTTLE BODY (eg6ajk)
thanks for that what size is the bore dont mean to sound silly but what does the map sensor do a how can it work from the fire wall. i am from england so model numbers are different. what engine is in the DX in case i cant find a late tb from a b or h and need map sensor.
Thanks again
team night spirt out
Thanks again
then look for any B16A, B18C TB, they are 60-62mm in size, the Map (manifold pressure), just basically look for one that looks like your as far as sensors but from b16a or b18c or h22a engine...
EgSalad
06-06-2007 12:12 PM
civichatch67
09-21-2005 10:11 AM
