Three turbo questions, need help.
1. If I use the hf manifold for turbo, what do I do about the wastegate?
2. Can I keep a/c with the hf?
3. My y7 manifold looks the same is there a difference?
thanks for the help guys!!
I did but nobody seems to want to help there, and this is where I'm always at. I know there are a lot of guys running turbos in this forum. Hell I've helped people with turbo questions on here before and so have others.
Modified by solsteeler at 5:12 PM 1/12/2004
Re: Three turbo questions, need help. (solsteeler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsteeler »</TD></TR><TR><TD CLASS="quote">1. If I use the hf manifold for turbo, what do I do about the wastegate?
I did but nobody seems to want to help there, and this is where I'm always at. I now there are a lot of guys running turbos in this forum. Hell I've helped people with turbo questions on here before and so have others.</TD></TR></TABLE>
With the HF manifold, you have two options. Get an internal wastegated turbo or have a external wastegate "port" fabricated. IF you want to go external wastegate I recommend against using the HF manifold. Get something that already has the external wastegate port on it. I personally dont wouldnt want to do too much fabrication on a stock manifold.
I am not sure on the A/C...I dont have it
No clue....never seens a Y7 exhaust manifold
I don't believe AC can be kept with the HF manifold set-up. http://www.homemadeturbo.com
