Thinner Headgasket
Thinner Headgasket
What does raising the compression do to the powerband? Does it increase hp/tq over the entire band or do you sacrifice somewhere?
Also, if one were to do this, what kind of tuning would be needed, as in timing etc.
Thanks
Thanks
Re: Thinner Headgasket (Wallace996)
don't expect more then 2-3whp from simple headgasket change, its not worth it unless you need to do it, save your money, and put it where it counts
but if you do the timing gets retarded (slightly)
It'll pretty much move the whole torque curve up across the whole band, by how much depends on the change in the CR; but im not sure about your method being good or bad.
Re: Thinner Headgasket (eg6ajk)
yeah, dont change a gasket for the sake of just exchange..wait till u really need one then upgrade, ur throwing away good $$ if that the case
New User
Re: Thinner Headgasket (deepnite)
Lowering the compression increases power output over all ranges in any engine. Its simple thermodynamics. Buy a book on thermodynamics if you dont beleive me.
Re: Thinner Headgasket (samdawgsol)
[Modified by Frog1342, 9:11 PM 2/28/2002]
onelostcoupe
22
10-13-2017 12:40 AM
ashb82
Engine Management and Tuning
06-15-2011 08:08 AM
buffgsr
06-06-2010 12:30 PM
