thermoswitch help guys????
i need to know where the fucking thermnoswitch is in a b18a1 block... is it in the back near the oil filter or is it located like the d16z6 one???????
please need your help guys.... https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: thermoswitch help guys???? (schtozo)
i'm not sure if there is a major difference with the location for a b18a or b18b but, with the b18b, it is located on the thermostat housing. just follow the lower radiator hose to the side of the block underneath the distributor.
Make sure you have a big ass open end wrench also. I used a SAE size wrench to take off the factory one and put on my Mugen. The largest metric I have is 19mm and it required one much much larger.
_______ |
Re: thermoswitch help guys???? (boostedeg6)
i'm not sure if there is a major difference with the location for a b18a or b18b but, with the b18b, it is located on the thermostat housing. just follow the lower radiator hose to the side of the block underneath the distributor. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
i'm not sure if there is a major difference with the location for a b18a or b18b but, with the b18b, it is located on the thermostat housing. just follow the lower radiator hose to the side of the block underneath the distributor. |
yeah but the thermostat housing in my block doesn`t have any shit... but it has something in the back of the block beside the oil filter... i always thought that it was the knock sensor but a friend of mine said that it maybe the thermoswitch... so what do ya think??? |
