test pipe with stock muffler....how does it sound?
Re: test pipe with stock muffler....how does it sound? (sicones)
How are you running a test pipe but a cat?? I thought a test pipe deleted the cat. UNless you mean the one on the manifold.
I would think it sound raspy.
Re: test pipe with stock muffler....how does it sound? (teknoracing)
no.. i have a stock integra cat in now, but am wondering what a test pipe would sound like in its place. would it really sound that bad with a oem muffler?
Re: test pipe with stock muffler....how does it sound? (aholeb18)
probably, but try it, if you like it, who cares what everyone else thinks. It should sound pretty quiet at low to mid throttle tho.
Re: test pipe with stock muffler....how does it sound? (fast95eg8)
there's no point in removing your cat, 1-2hp MAYBE at most. Dont pollute this planet more than need be.
Keep the cat. remove resonator, that should make it slightly louder and better flowing.
does anyone have this set up? i don't want to know what it "probably" sounds like. thanks for the replies though
i ran test pipe on stock civic piping and stock rear section... sounds like sh** real raspy around 4k and then gets deep
personall exsperience, i have a straight / test pipe, I ran with a greddy evo 2. didn't want the loud exhaust anymore, put on a stock si exhaust with the test pipe still on, no rasp at all, sounds deep, nothing special, just more air going straight out, it won't be raspy unless your gutting a cat and fail to remove any lose parts, then it will be raspy. otherwise go for it.
Re: (YoungKadafi)
it would sound like this .. . "bwwwwwwwwwaaaaaaaaaa" j/k. not sure how you're going to get an idea by asking how will it sound, unless someone has a video/sound clip
Re: (La-quiete)
this is from personal experience, i actually have a test pipe in place of the catalytic converter on my 96 civic w/ a b16 swap. 2.25 piping and i kept the stock muffler and resonator, sounds deep when givin'r not raspy at all. hope this helps!
Re: (La-quiete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-quiete »</TD></TR><TR><TD CLASS="quote">Its annoying</TD></TR></TABLE>
DC header, no cat, and a stock DX muffler on a b20. It sounds like ****. I thought it would be quiet because of the stock muffler, nope, it just buzzes along. I'm not kidding. It sounds like ****.
Re: (pinoyboy204)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboy204 »</TD></TR><TR><TD CLASS="quote">this is from personal experience, i actually have a test pipe in place of the catalytic converter on my 96 civic w/ a b16 swap. 2.25 piping and i kept the stock muffler and resonator, sounds deep when givin'r not raspy at all. hope this helps! </TD></TR></TABLE>thanks. this is my exact set up. i'm hoping i have the same luck as you. i just hate to blow $90 bucks on a decent test pipe to hate the sound. after putting the oem muffler back on, i can't seem to get used to how quiet it is. thanks for the replies, it gave me a good idea of what to expect. hope this helps someone else too.
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing »</TD></TR><TR><TD CLASS="quote">there's no point in removing your cat, 1-2hp MAYBE at most. Dont pollute this planet more than need be.
Keep the cat. remove resonator, that should make it slightly louder and better flowing. </TD></TR></TABLE>
Well if your state doesn't require you to pass emissions why not say expletive it and go ahead and get the 3+ whp out of it..
One person running a test pipe isn't going to effect the ozone layer any worse then it ******* is now..
Omnipower test pipe
Omnipower test pipe
Re: test pipe with stock muffler....how does it sound? (La-quiete)
i have a resonated test pipe, 2.36" b pipe and stock integra axle back. right at 4k rpm theres some nasty rasp. but cruising its fine and above 4500 its fine. sounds like *** on the gas at 4k though.
Re: test pipe with stock muffler....how does it sound? (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
Omnipower test pipe </TD></TR></TABLE>
Well, imagine if everyone said that there would no ozone layer. 3WHP isnt shhh. Plus i hardly doubt he can feel 3HP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Well if your state doesn't require you to pass emissions why not say expletive it and go ahead and get the 3+ whp out of it.</TD></TR></TABLE>
Personal responsibility?
Be a man, not a weasel.
Re: (93civic_sedan)
fabbed up a test pipe tonight, and guess what....it sounds fine. just slightly louder with the oem muffler. didn't hear any raspy/ricey sound at all. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing »</TD></TR><TR><TD CLASS="quote">
Well, imagine if everyone said that there would no ozone layer. 3WHP isnt shhh. Plus i hardly doubt he can feel 3HP.</TD></TR></TABLE>
i didn't respond to this because i feared this type response. do you really think cat/converters are saving the planet. i know this is a step, but seriously, imo there is so many things wrong in this ******* world.....cars without cats aren't one of them.
Actually, Catalytic converters make an even more potent greenhouse gas which is WORSE for our ozone then smog. Nitrious Oxide.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiki »</TD></TR><TR><TD CLASS="quote">
http://en.wikipedia.org/wiki/C...rters
Catalytic converters have proven to be reliable devices and have been successful in reducing noxious tailpipe emissions. However, they have two adverse environmental impacts in use (ignoring the pollution caused in their manufacture, which would not exist were they not mandated):
The requirement for the engine to run at the stoichiometric point means fuel economy is not as good as that of a "lean burn" engine running at a mixture of 20:1 or weaker. This increases the rate at which fossil fuel resources are consumed, and the carbon dioxide emissions of the vehicle.
Catalytic converters are estimated to account for 50% of total nitrous oxide (dinitrogen oxide, laughing gas) emissions to atmosphere. While N2O emissions in these concentrations are not harmful to human health, N2O is a potent greenhouse gas, accounting for around 7% of the overall greenhouse effect despite its small concentration in the atmosphere.
Therefore one conclusion is that catalysts have reduced toxic emissions and the incidence of smog at the expense of increased global warming.
I have an obd1 j-spec b16a, dcsports header, test pipe, 2 and a half inch exhaust, no resonator, and a short straight through muffler. people can hear me miles away. it is loud and ricey. i am always afraid of being pulled over. i do not recommend this setup. BUT......... It is fun to blow past the car your racing with the engine screaming.
Just get High Flow Cat. U will get better air flow but no noise. In CA u can get fine up to $2500 for removing cat...
YellowR2000x2
04-08-2003 01:22 PM
