Temperature Sensor Maybe?
1999 Civic EX Coupe: So I'm having a consistent issue with my car that only happens when the weather gets cold. The car will not start when the temp gets near freezing. I have spark, fuel pressure & compression. When I put/push the car in the garage overnight, it will start by flooring it, for several seconds, until it warms. From my search on the site, could this be the temperature sensor located in the cylinder head?
Re: Temperature Sensor Maybe?
There are two temperature sensors feeding the ECU, the coolant sensor in the head under the distributor and the air temperature sensor in the intake. Both can be checked with an ohmmeter comparing the actual resistance to the expected resistance vs temperature chart in the service manual. It is possible for a sensor to go out of spec causing runnability problems but not so far out that the ECU will throw a code. Of course if any codes are present you need to resolve them.
Thanks for the replies. I don't have any CEL codes. What section of the service manual will have the resistance values? Thanks again.
· 0 Falha na Central - ECU ou alimentação elétrica;
· 1 Sensor de oxigênio;
· 2 Falha na Central - ECU ou alimentação elétrica;
· 3 Sensor MAP;
· 4 Sensor de rotação ou falha no sensor 1 de rotação e PMS;
· 5 Sensor MAP - Entrada de ar ou mangueira de vácuo do sensor MAP;
· 6 Sensor temperatura da água;
· 7 Sensor posição borboleta;
· 8 Sensor de rotação ou de fase/Sensor PMS ou falha no sensor 2 de rotação e PMS;
· 9 Sensor de fase;
· 10 Sensor temperatura do ar;
· 11 Falha na Central - ECU ou alimentação elétrica;
· 12 Válvula EGR - Recirculação de gases;
· 13 Sensor de pressão barométrica;
· 14 Válvula de controle de marcha lenta;
· 15 Sistema de ignição - Sinal de saída do módulo de ignição;
· 16 Válvulas injetores;
· 17 Sensor de velocidade;
· 18 Ajuste de ignição;
· 19 Válvula solenóide de controle A/B da transmissão automática;
· 20 Possível circuito mau aterrado na ECU - Falha no sensor de leitura elétrica;
· 21 Válvula solenóide VTEC;
· 22 Interruptor de pressão de óleo VTEC;
· 23 Sensor de detonação;
· 30 Falha no sinal "A" da transmissão automática;
· 31 Falha no sinal "B" da transmissão automática;
· 41 Sensor de oxigênio esquerdo;
· 42 Sensor de oxigênio direito;
· 43 Circuito de alimentação de combustível esquerdo;
· 44 Circuito de alimentação de combustível direito;
· 45 Sistema de injeção - Falha no controle da mistura (rica ou pobre);
· 48 Sensor de oxigênio;
· 50 Sensor de fluxo de ar;
· 54 Sensor de rotação - Sensor 2 e PMS;
· 58 Sensor de rotação e PMS;
· 59 Sensor de fase;
· 61 Sensor de oxigênio (frontal);
· 63 Sensor de oxigênio (traseiro);
· 65 Sensor de oxigênio (traseiro);
· 67 Sensor de oxigênio (traseiro) ou catalisador eficiência baixa;
· 70 Transmissão automática;
· 71 Falha de ignição "cilindro 1" ou elétrica / mec nica;
· 72 Falha de ignição "cilindro 2" ou elétrica / mec nica;
· 73 Falha de ignição "cilindro 3" ou elétrica / mec nica;
· 74 Falha de ignição "cilindro 4" ou elétrica / mec nica;
· 75 Falha de ignição "cilindro 5" ou elétrica / mec nica;
· 76 Falha de ignição "cilindro 6" ou elétrica / mec nica;
· 80 Fluxo insuficiente no sistema de recirculação de gases - EGR;
· 86 Sensor temperatura da água;
· 90 Falha no sistema evaporativo do tanque;
· 91 Falha no sensor de pressão do tanque;
· 92 Válvula do c nister;
It's in portuguese. Sorry for that.
But is this what are looking for?
LuckyJDM
12-08-2012 10:28 PM
