temperature rises as car gets faster
Old 07-11-2002, 10:09 PM
gohandbz8's Avatar
Default temperature rises as car gets faster
As the topic says, the engine temp on my car gets hotter when i go faster on my car. Anywhere below 75mph my car is running at normal temperature, but when i go higher than that it gets to the point where its almost going to overheat but it doesn't.
I have recently flushed my radiator and I have swapped out a new thermostat already. Can you guys enlighten mean on what else can be the cause of this problem. Any help would be appreciated. Thanks
Old 07-11-2002, 10:16 PM
madhatch's Avatar
Default Re: temperature rises as car gets faster (gohandbz8)
could be a faulty waterpump, as the engine revs higher the impeller could be slipping or vibrating decresing flow. Also could be the radiator could be clogged a little or may be losing pressure. Presure would normally be all the time but who knows. Run a pressure leak test. Then check your water pump.
Old 07-11-2002, 10:39 PM
.nate's Avatar
Default Re: temperature rises as car gets faster (madhatch)
I had this very same problem, and it turned out to be my raidiator. It may not be your problem, but you might want to swap raidiators with a friend for a sec to see if thats really the problem. I know you said that you just had it flushed, but you never know...
Other then that all I can think is that it could b the waterpump or head gasket...
Good Luck!
-=Nathan
Old 07-11-2002, 10:41 PM
migs's Avatar
Default Re: temperature rises as car gets faster (N8)
Your flux capacitor might of blown a fuse.
Old 07-11-2002, 10:47 PM
gohandbz8's Avatar
Thanks for the help guys. I'll go get a compression test and maybe i'll try to swap a radiator with my friend and see if thats the problem.
instructor74
11-20-2008 06:29 PM
kyden
06-20-2006 09:25 PM
fernruffryders
06-03-2006 08:06 AM
Redirwol1
Honda S2000
03-20-2005 08:51 PM
CptCorN
28
02-06-2005 06:23 PM
Quick Reply: temperature rises as car gets faster
