Temp guage not working!!!
I have an EG with a ls/vtec swap. The guage worked last week and all I changed was the transmission and clutch. The fan still cuts on and of but all the sudden my temp guage does not work. Any suggestions?
Re: Temp guage not working!!! (ckyfan87)
did you clip the head temp sensor back on? its on the side of your head, probably under the upper radiator hose outlet.
Re: (ckyfan87)
there is only one temp sensor and it's under the dizzy. it has the needle plug just like the oil pressure sending unit but smaller. your probably aslo thinking of the fan switch which is on the thremostate housing. some people thinks that's the temp sensor.
Re: (kay20adc2)
not to thread jack but im heaving the same problem too and im kinda worried.. now my temp needle will go up but only to the bottom of the cold line... this was after an hour and a half of driving and it didnt go up to its normal temp.. plz help guys
Re: (egmatt93)
Found the problem. It was the push in plug under the dizzy. The wire ripped out of the plug. Thanks for the help, works great. But now my brake lights won't work. I checked fuses. I think it is the brake switch. Its always one thing after another.
mattcivic
08-20-2008 12:14 PM
Bb16ahatch
03-09-2007 03:40 PM
cstem
11-21-2003 07:58 PM
