Tell Us What You Did To Your EG/EK/Del Sol Today
Old 12-06-2016, 12:54 AM
  #3251
Fish Twig
tony_2018's Avatar
Default Re: Tell Us What You Did To Your EG/EK/Del Sol Today
Originally Posted by 98civdx
A deep socket will fit right over the dog bone.
Dammit, the smaller bushings have a softer metal ring or something. Damaged one on the rear compensator arm.
Old 12-06-2016, 11:46 AM
  #3252
Master Detailer
98civdx's Avatar
That's very easy to do, I messed up on the TA bushings. You aren't alone. You are able to buy the bushing separately so you aren't totally screwed.
At least you didn't bend the compensator arm like I did.
Old 12-06-2016, 12:29 PM
  #3253
Fish Twig
tony_2018's Avatar
I think my issue is that the rust around the bushing is keeping it in there pretty good.
I got kroil, I'll spray it on the TA bushing to loosen it up a bit.
Old 12-09-2016, 08:43 PM
  #3254
chrysler kid's Avatar
Tearing it apart for maintenance, checking for top dead center and found it was a Honda belt. Inspection further determined a fresh cam seal, a shiny tensioner spring, honda stamp on the water pump with shiny new bolts.
So I'm good on this pieces, into the underside which is a complete disaster with oil everywhere. I thought it was possibly a bad rear main, but closer inspection showed tons of build up over the entire oil pan, but the major leak was confined to the end by the trans.
Clean inside. Notice the wet oil stains on the block where the gasket use to rest lol
Not joking 3 inches of sludge down there on the outside of the pan. Inside was clean
That's nasty. See the gasket? No, that's because the rubber was hard and brittle and broke apart. It is still on the pan in this picture
Old 12-17-2016, 09:14 AM
  #3255
Norbi Buddyclub's Avatar
Old 12-17-2016, 05:35 PM
  #3256
Northernlightz's Avatar
K
Old 12-20-2016, 07:37 AM
  #3257
SiR_Chris's Avatar
Today I managed to get my delsol into a magazine! 6 page feature spread, so chuffed!
Not sure if you guys get this mag in the USA??
Old 12-20-2016, 08:08 AM
  #3258
talks to himself
CX-Adam's Avatar
Congratz!
Old 12-20-2016, 08:31 AM
  #3259
fluke702's Avatar
Nice build! What are you rims/tire combo size are you running?
Old 12-20-2016, 09:07 AM
  #3260
Premium Member
94 Civic Si's Avatar
That is nice!!!
Old 12-20-2016, 09:49 AM
  #3261
Corvette Forum Member
LiteraCola's Avatar
My new Depot headlights should be arriving this afternoon! I'll probably spend some time tinkering with them until my fingers go numb! The original headlights are reflecting nearly ZERO light since the reflective foil on the inside of the housings is all but gone! No wonder I can't see anything!
Old 12-20-2016, 04:52 PM
  #3262
civic402lx's Avatar
Installed heated seat pads.. Nice and toasty..
Old 12-21-2016, 04:33 AM
  #3263
SiR_Chris's Avatar
Cheers! They are 16x8 ET20 but with 10mm spacers, and Yoko AD08R 215/45/16
Old 12-28-2016, 03:36 PM
  #3264
pinkdelslo's Avatar
Found that my beater del slo (aka the framebanger 9000) is burning oil at a incomprehensible rate. Just going to keep topping her off until I can finally junk the poor girl and my GSR buy a new daily.
Old 01-01-2017, 04:24 PM
  #3265
StevoDVS's Avatar
this past Friday from USDM to UKDM with working ashtray LED light and (now) charging power outlet.
Old 01-01-2017, 04:27 PM
  #3266
StevoDVS's Avatar
swapped out the ol' GS-R shifter for a nice and smooth shifting K-Tuned shifter yesterday...I KNOW I KNOW I KNOW...I'LL SWAP OUT THE OLD GS-R SHIFT ****
Old 01-02-2017, 10:46 AM
  #3267
Hysterically Calm
TomCat39's Avatar
It was Friday when we had good weather, but I did the vtec seals on my swapped D16Z6.
So far no leaks as I made sure to clean all the surfaces with brake cleaner and also let all the oil drain out of the bottom port prior to installing the new gaskets. I think people don't remove all oil from the mating surfaces either by not thoroughly cleaning or not allowing the oil to fully drain out to keep the surface oil free before install and end up with a leak.
I also poor man wrapped my wife's steering boot on her EH2 so as to keep the water, dirt and salt out of the inner tie rod until summer when I replace all the tie rods and install new OEM boots.
It's too bloody cold to be working on cars extensively outside!
Old 01-03-2017, 08:48 AM
  #3268
Premium Member
Agreed! And our high for Thursday is forecast @ 9 degrees F...
Old 01-06-2017, 04:48 AM
  #3269
Fish Twig
tony_2018's Avatar
I officially fucked up on 1 of the upper control arm bushings so now I'm gonna have to order another as well as 1 bushing for the compensator arm. I'm making head way with the deep sockets I need to hold and push, and finding methods to press in the new bushing with a big *** C clamp, or the ball joint kit from autozone.
Old 01-06-2017, 11:51 AM
  #3270
Master Detailer
98civdx's Avatar
I tried that method, it was working for me. Luckily I have access to a press.
But at least you are making head way with the bushings, that's the biggest hurdle.
Old 01-06-2017, 04:11 PM
  #3271
Fish Twig
tony_2018's Avatar
one I know that helped was to lubricate it before pushing in a new bushing.
Old 01-08-2017, 12:45 PM
  #3272
silver97S's Avatar
i had a misfire on friday, unfortunately, and wasnt able to get to it until today. i had to do an oil change too so it worked out. all four plugs were pretty nasty. honestly i dont think you could tell which one was misfiring if you didnt have the code checker. anyways, i replaced 'em and had to re-gap them since the manual says 44ish and the ones i pulled out of the car were at 55 and the new ones were about 37. the car runs 10x smoother now.
i mean, it still smells like gas and oil and still burns oil which you can clearly see out the tailpipe but at least it runs better. i'm glad i didnt post earlier, that show car a few posts back would have really made my car look bad!
Old 01-26-2017, 04:16 PM
  #3273
Nave43's Avatar
Icon6 Re: Tell Us What You Did To Your EG/EK/Del Sol Today
Plastic clip in the wiper armature decided to self destruct. Mono wiper ftw.
Old 01-27-2017, 05:42 AM
  #3274
LiteraCola's Avatar
I'm gonna be tackling VTEC solenoid seals this weekend, and continue in my investigation of the mystery dizzy oil leak. Last night I ordered LCAs, UCAs, tie rods, new shocks and some TEIN S-tech springs. And I said I wasn't going to modify this car. Damnit, man.
Old 01-27-2017, 10:04 AM
  #3275
Premium Member
Did you get them under the upholstery?
I would like to install some. Wonder if I can wire them to some power window switches? My '94 EH3 has blanks for window switches, could look like factory...
Quick Reply: Tell Us What You Did To Your EG/EK/Del Sol Today
