teg seats in a ek
Do these swap in with all four bracket wholes lining up right, or do I need to use my brackets off my stock seats? Please only responses from people who have swapped them.
Re: teg seats in a ek (StRacer)
1. do a search. this seems to be covered once a week.
2. are you doing the front seats, back seats, both? specify. 3. civic coupe or hatchback? front seats how to: 1. remove civic seats from car. 2. take off inside seat rail from stock seat. 3. take off inside seat rail from integra seat. 4. install civic rail onto teg seat. 5. install into car. this gives you the seat belt buckle from your civic and all four holes line up. you'll have a little color variation (i have dark gray interior and the teg sides are black) but it's nothing noticeable. hope that helps. take a look at both seat rails and it will all make sense. rear seats won't fit right. the bottom cushion will have a gap on either side. if you have a coupe, the seat backs won't fit. the teg and civic hatchback both have 50/50 split so it can fit. i have a coupe, so i only did the fronts. |
