Tech HELP!!!
Tech HELP!!!
I screwed up my injectors with the wiring. Anyhow... I reconnected some wires. My question is..... How will I know if I'm running on three cylinders? The check engine light will come on right? If thats the case how come I feel like I am missing power? Is it because I didnt properly restart the car correctly after the ECU reset? The car lacks power now and I dont know whats going on.
It aLso idles at about 600 rpm. Any ideas?
[Modified by Civic LX 29, 1:13 AM 7/23/2002]
Re: Tech HELP!!! (Civic LX 29)
While the car is running, you can pull the conector off the injector, and it should rurn rougher, if not you found the problem injector.
revtech motorsports
03-22-2005 03:03 PM
