tachometer jumping around
i put in a autometer tach and it jumps around from time to time? why is this? also it sometimes says its at 4 grand when my stock tach says 2 grand then it will jump to the right spot?
Re: tachometer jumping around (BADEG6)
i have it grounded to the hood pop latch and i ran the tach lead to the distrubutor on the negative terminal on the stock honda coil.
Re: tachometer jumping around (Civic_EX_turbo)
why wire it to the distributor when there is a wire made to have an external tach ran to it...its up by the strut tower on the right side...its a single blue wire. try grounding it in a better spot...
Pooping on children
Re: tachometer jumping around (redcivicgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcivicgsr »</TD></TR><TR><TD CLASS="quote">why wire it to the distributor when there is a wire made to have an external tach ran to it...its up by the strut tower on the right side...its a single blue wire. try grounding it in a better spot...</TD></TR></TABLE>.
because the wire from the dizzy is the most accurate spot to wire the tach
Pooping on children
Re: tachometer jumping around (ci9v7ic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ci9v7ic »</TD></TR><TR><TD CLASS="quote">blue wire on dizzy. </TD></TR></TABLE> im not sure but is the wire on the dizzy the same color from eg to ek?
99sibluehatchwitb16
01-26-2006 09:45 PM
