Tachometer on a 99'
Tachometer on a 99'
Hey, I have a 99' Honda Civic DX, w/o a tachometer.
This is obviously not a race car, its just my daily driver to school
and i was looking to add a tach, it does help sometimes,
What do you guys recommend I get, Just a tach to bolt on the side of door
or console, or get a whole new guage cluster (dunno about this) where
would be best place to put it. And can i assure it will be 100% perfectly calibrated
accurate rpm's
Thanks
accurate rpm's
Thanks
Global Moderator
Re: Tachometer on a 99' (Re3irth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Re3irth »</TD></TR><TR><TD CLASS="quote">Hey, I have a 99' Honda Civic DX, w/o a tachometer.
accurate rpm's
Thanks</TD></TR></TABLE>
Try searching gauge clusters..also you could an an EX gauge cluster but if you like looks more i'd go for an si cluster and yes it will be just as accurate as a civic ex would be stock.
accurate rpm's
Re: Tachometer on a 99' (USDMDC2)
how hard would it be to install a full cluster im thinkin pretty hard,
remove the oil level guage and heat guage and all other guages,install new
ones and wire each one back to its original area, most of the car has to be
gutted it seems,
So you dont think i should get just the tach? because then i can leave all the
stock things in place and just wire the tach.
gutted it seems,
dont put a tach on the pillar imho. as far as changing out the cluster, 6 phillips screws, unplug your cluster plug new one in. simple.
Re: Tachometer on a 99' (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub »</TD></TR><TR><TD CLASS="quote">dont put a tach on the pillar imho. as far as changing out the cluster, 6 phillips screws, unplug your cluster plug new one in. simple.</TD></TR></TABLE>
yes it is quite simple, just unscrew the 6 screws and unplug the cluster and the new one you get with a tach will plug right up, regardless if it is Si or Ex or whatever!
Re: Tachometer on a 99' (R33CIVIC)
I thought i would have to run the tach sensor somewhere
(again i have a 1999 civic dx w/o a tachometer)
so how is it just plug and play? i never took the cluster apart
so there is just one plug for everything?
Your vehicle is already prewired for a tachometer. It's the blue wire behind your dash. Everything is plug and play. You could also swap your odomter to retain your mileage. There will be one-two plugs that won't be used depending on your vehicle. There's a green plug on the EX/Si cluster you won't use. That's for cruise control. The other is if the cluster is automatic and yours is 5spd. You won't need the plug that goes to the gear indicator.
Thanks for the help didnt see your message, just one more important thing...
Also what civic years and trims will work with my car because
i plan on hitting a few junkyards around me looking for a cluster.
Modified by Re3irth at 1:57 AM 2/23/2004
Re: (Re3irth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Re3irth »</TD></TR><TR><TD CLASS="quote">^^^</TD></TR></TABLE>
Wait for more than 10 minutes and I'm sure someone will answer you. You need any cluster out of a 96-00 civic that has a tach. I got one from an EX, but a SI and I believe an LX and HX will have one as well. As far as the shift light it helps if you are really racing (on a track) so you know when to shift without taking your eyes off of the track to look down at your tach. For street driving it's pointless IMHO.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Wait for more than 10 minutes and I'm sure someone will answer you. You need any cluster out of a 96-00 civic that has a tach. I got one from an EX, but a SI and I believe an LX and HX will have one as well. As far as the shift light it helps if you are really racing (on a track) so you know when to shift without taking your eyes off of the track to look down at your tach. For street driving it's pointless IMHO. </TD></TR></TABLE>
Yea thats the only reason for the shift light, no need to get one really for the street.
i HAS questions ?
Re: (PriMaTe)
I was in the same situation about a month or so ago. http://www.woodfins.com is where I got mine from. I don't think it was anymore than like $50. Also took about 4 days to get it, and it was in mint condition. I ended up getting an automatic cluster, but oh well, it'll just confuse people even more.
Soliveros15
28
03-02-2014 12:46 PM
Sketch_hs
05-12-2003 07:11 PM
JDM CRX
02-20-2002 11:13 AM
JD_B18CDX
11-06-2001 09:02 AM
