Tachometer???
Old 07-15-2007, 03:01 PM
J.Berta's Avatar
Default Tachometer???
I have a 94 eg. I've had a sohc non-vtec and an LS motor in the car and the tach worked fine. But when i put a gsr motor in it, the tach still stops at 7000 rpms. I have a itr swap in it now, and the same thing. 7000 rpms and the tach stops there. My car has been tuned to 8500 rpms, so i know that it should be goin further. I have a auto meter pen size shift light in it, and it is right on with the ecu. And i have already changed gauge clusters. Has anyone else had this problem? And how did you fix it?????? if you did..Thanks
Berta
Old 07-15-2007, 03:07 PM
94c1v1cex's Avatar
Default Re: Tachometer??? (J.Berta)
stock tachs aren't very acurate at all... get an aftermarket one and see if it works better
Old 07-15-2007, 03:11 PM
J.Berta's Avatar
i would think that it would go past 7k since the ls would make it there.?.
Old 07-15-2007, 03:23 PM
94c1v1cex's Avatar
Default Re: (J.Berta)
your tach just stops going at 7k? and your motor keeps going? why are you trying to rev to 8500 anyways?
Old 07-15-2007, 04:22 PM
J.Berta's Avatar
its like its out of syns. When the motor is at 8500, the tach is at 7200. 8500 is where my itr motor stopped making power when i got it tuned..
Old 07-15-2007, 06:18 PM
94c1v1cex's Avatar
holy hell thats high... but ya stock tachs are way off and the higher the rpm the more off mine gets so maybe yours is just really bad... sadly to say 1300 off
Old 07-16-2007, 02:51 PM
J.Berta's Avatar
8200 is the rev limit on the factory ecu for gsr and itr. So mines goes alil beyond by 300. Not too high.
Old 07-16-2007, 03:14 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.Berta &raquo;</TD></TR><TR><TD CLASS="quote">8200 is the rev limit on the factory ecu for gsr and itr. So mines goes alil beyond by 300. Not too high.</TD></TR></TABLE>
not to be nit picky, but the ITR (P73) red lines at 8400 and rev limit is at ~8700.
the GSRs revlimiter is 8200, red line is slightly lower.
I ran up to 8500 RPM on my 92 civic cluster with no problem. It simply went past the markings.
where did you tap into the tach line? from the ECU or from the distributor?
does the engine seem like it runs ok higher than 7k? (signs of a bad ignitor)
Old 07-16-2007, 05:26 PM
J.Berta's Avatar
It runs fine, like it did on the dyno. No hesitation at any time. I'm using the factory tach only. And for the shift light, i plugged in to the tach test plug at the brake booster.
Old 07-16-2007, 05:37 PM
Syndacate's Avatar
Borrow an aftermarket tach and see what that shows you.
Old 07-16-2007, 05:44 PM
sageuvagony's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
does the engine seem like it runs ok higher than 7k? (signs of a bad ignitor)</TD></TR></TABLE>
??? My 92 cluster shows up to 9,000?
Old 07-17-2007, 05:16 PM
J.Berta's Avatar
^^^^my dash tach shows 9k too, but the needle wont go to the estimated rpms...
Eg tipe r
06-02-2011 08:52 PM
hondaeg8
08-20-2004 04:34 PM
uncleben
04-15-2002 07:39 PM
Quick Reply: Tachometer???
