Tach wiring
Re: Tach wiring (rspectuning85)
don't even worry about running it all the way to your tach. There is a blue wire on the driverside firewall that you hook into looks much cleaner and works the same. i don't have a pic of it but i am sure someone here does.
Re: (rspectuning85)
open your hood go to the clutch cylinder (where you add fluid) and look at those wires you see in front . you will see a blue wire with a rubber cover on it.. tap into that wire..
gearhead16
02-18-2007 11:39 AM
b18c5ivic
15
09-15-2002 06:21 PM
