Tach problem idels at 100 rpm or 0 rpm
After take my car to the shop to get some stud replaced, i got in the car and fired it ip and the tach read 0 rpm. When i drive it fine revs mostly match speed and rev. But when it idels it drops to 0 rpm or 100. Not ideling rough.
WHat could this be? |
Re: Tach problem idels at 100 rpm or 0 rpm (Average Al)
ignitor? its what sends the signal tou your tach
where would this be located and repair cost?
Re: (Average Al)
in your distributor around 80 bucks
Re: (92lxsedan)
it has 4 wires attached to it, the blue one is for your tach, make sure its plugged in and hasnt came loose
any other suggestion?
Re: (Average Al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al »</TD></TR><TR><TD CLASS="quote">any other suggestion?</TD></TR></TABLE>
Check to make sure the wiring to the actual tach is not loose or messed up...... |
Will d15 dizzy work in a d16?
i check the output signal tommrow in the daylight i keep updated |
up again
Re: (Average Al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al »</TD></TR><TR><TD CLASS="quote">Will d15 dizzy work in a d16?
i check the output signal tommrow in the daylight i keep updated</TD></TR></TABLE> Not properly. |
