Is the tach lead on 5G HB's still blue? I know it is on 4G's....trying to hook up a tach!
Do i need to tap into the blue lead coming out of the cluster? And what color wire is going to be 12V ignition switched?, and then also the 12V dash lighting? I did a search but didn't come up with anything. I don't want to rig all these to the fuse panel unless i have to any and all help appreciated
also, is a 92 HB (with LS swap) a '2pulse' or a '1pulse' system? Cuz i have to cut some wires depending on what it is
[Modified by hot_EF, 6:29 PM 4/8/2002]
Re: Is the tach lead on 5G HB's still blue? I know it is on 4G's....trying to hook up a tach! (hot_E
c'mon, i want to go hook this up now!!!!!
I'm not to sure about inside the dash, but out in the engine bay, on the driver's side by the hood prop and DRL module there is a single plug with a blue wire running from it. It's the tach diagnostic port, and you can then use that and run the signal wire into the cabin.
best of luck!
best of luck!
Is this a monster tach? Cuz I have one sitting here...but it seems TOO big to fit along side of the Apillar. Any pics of ur install when ur done?
-Rod
-Rod
D Tranny Guru
best of luck!
best of luck!
It is usually taped to the main harness.
Be surprised what you info you find in a Helms when it is in the bathroom.
OutLuDeD
03-02-2003 02:09 PM
One2hit
07-10-2002 10:27 AM
