tach jump/sputter eg mini me swap
Old 04-24-2011, 12:41 PM
svtford4x4's Avatar
Default tach jump/sputter eg mini me swap
just got the mini me swap done ran the vtec wires to the ecu no CEL with the p28 ecu
the tachometer jumps and the car sputters around 3000rpms
the timing light lines up with the tdc mark when placed on the #1 cylinder is the timing belt off?
i thought everything was lined up but the timing marks were not even close so i moved it over a tooth and now its lined up with white tdc mark
Old 04-24-2011, 01:19 PM
ktsciv93's Avatar
Default Re: tach jump/sputter eg mini me swap
you don't line the tdc mark up when doing ignition timing... theres 3 ignition marks. line it up with the middle ignition mark for stock timing. 2 degrees neg or pos are the other 2..
Old 04-24-2011, 02:10 PM
svtford4x4's Avatar
so you think my belt is a tooth off? i knew it was supposed to be on the red line, and the two lines next to that are 15 degree's i believe.
the sputtering is gone now same for the tach jump. it was loose igniter bolts
Old 04-24-2011, 02:16 PM
ktsciv93's Avatar
no. i think ur ignition timing is wrong. when you set timing with a timing light you set it to the middle of the 3 marks. not the tdc mark
Old 04-24-2011, 02:17 PM
svtford4x4's Avatar
i dont think there is enough adjustment in the dizzy to move it from the white tdc mark to the red mark
Old 04-24-2011, 02:48 PM
Former User's Avatar
Make sure to jump the service connector and that the engine is idling to spec when checking/adjusting the ignition timing. If you can't align the pointer with the red mark, then the mechanical timing is still off by a tooth.
Old 04-24-2011, 02:50 PM
svtford4x4's Avatar
thats what i was wondering, the service connector was jumped
but i moved the belt over a tooth when it had the idle problem so now i just have to move it back thanks.
Old 04-24-2011, 02:53 PM
ktsciv93's Avatar
what do u mean theres not enough adjustment? that's where its supposed to b!
Old 04-24-2011, 03:29 PM
svtford4x4's Avatar
it was the belt i put it back to where it was and let the engine warm up with the service connector jumped.
its timed to the red mark is there any advantage to slight advancement in the timing?
*felt the first vtec kick*
Old 04-24-2011, 03:49 PM
ktsciv93's Avatar
not really any advantage if you're not adjusting air/fuel with it...
Old 04-24-2011, 11:55 PM
svtford4x4's Avatar
thats what most people were saying in threads when i searched no benefit. and possible detination
so vtec kicks in just before redline whats up with that? right about 6500-6800 rpm
i don't notice a huge difference overall sounds louder when vtec kicks in.
JDMtype Eg6
09-03-2008 05:14 AM
supabang
08-03-2007 10:54 PM
NSfit
10
11-14-2006 11:17 AM
jdurston
06-09-2004 05:30 AM
kholmes
05-24-2004 07:01 AM
Quick Reply: tach jump/sputter eg mini me swap
