Tach Installation Help
I have a 94 Civic Coupe i neewd help hooking up a tach with the shift light. I think i found a the coil but where do i connect the wire to the coil. i need help A.S.A.P. any info would help
Re: Tach Installation Help (silvestri51)
In the engine bay, on the driver's side near the firewall is a single blue wire, tap into that. I don't have a picture of it, but it should be pretty easy to find. It's just a little bit to the right (if looking into the engine bay) of the clutch master cylinder.
Re: Tach Installation Help (******)
is it wrapped in like tape with a few other wires, cuz if so i found it, i found a blue wire wrapped up with a blue and white wire and two black wires and they were all wrapped in like a black tape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvestri51 »</TD></TR><TR><TD CLASS="quote">is it wrapped in like tape with a few other wires, cuz if so i found it, i found a blue wire wrapped up with a blue and white wire and two black wires and they were all wrapped in like a black tape.</TD></TR></TABLE>
It's actually a single wire. Here's an easier way. Remove your gauge cluster, and tap into the wires from the cluster harness.
Tach signal wire - BLUE wire
Power wire - BLACK/YELLOW wire
Lighting wire - RED/BLACK wire
Ground wire - ground to dash bolt
GSRCRXsi
05-22-2005 08:01 PM
