tach goes down instead of up
on my 2000 civic ex when i crank my car up the tach goes to 1000 rpm but when i give it gas the tach goes down to 0 instead of going up. anyone know how to fix this and does anyone know a web site i can go to to see what order the spark plugs are suppose to be my engine is idling very low and my timing is right
Re: tach goes down instead of up
ROFL
Your Dizzy has a serious issue. Thats probably why the car isnt running right.
You can go to sparkplugs.com or to advanceautoparts.com and you can find what kind of spark plugs you need. But the standard plugs for your car are ZFR5F-11. You can also use BKR5F-11. But if you are going to change your plugs I recommend E3 E3.48's as you will get a little more power and a little better gas mileage.
http://sparkplugs.com/results_app.as...1&AAIA=1363058
ok i got that fixed but now my car still runs like crap my a/f gauge is almost all the way down the lean side and i pulled my plugs out and there real black with carbon. whats is this saying
I have left on my car a 255 walbro fuel pump and an adjustable fpr. I tried turning the pressure down almost till the engine cut off and it was still running bad all the down. I had a cam, intake manifold and a whole bunch of other stuff on it before i blew the old motor up. I took everything off but those two. should i go ahead and take those two off and get it competly stock. that fpr just might not be doing its job the spring may be messed up inside it.
does the PSI go down as you adjust the FPR? Becaues if it does than the FPR is fine. The 255 LPH pump wont make the car run rich if the FPR is running right.
yeah I can see the pressure going down. The only thing I can think of is maybe my injectors got mixed up cause they all look alike. I have s2000 injectors and they might have got put in by mistake. I need to find a set of good used d16y8 injectors pretty cheap
Do S2K injectors even fit in the car properly? I would figure that they used a different clip or something? How big are S2K injectors anyway?
a guy gave them to me a while back and he said they s2000. They look the same as the civics and they do fit in the socket and the clips are same. I forgot what size they are I wanna say 320cc
And yes, a bad o2 sensor could cause you to run rich. It could be bad just from being so old, it's probably coated with junk causing the readings and adjustments to be off. Try a new one from ^ www.sparkplugs.com for like $45. And if it doesn't fix the problem 100%, at least you have a new o2.
TexasCheddar
10-14-2013 02:53 PM
madhatter
07-11-2004 04:15 PM
ImAcracker
04-04-2004 07:42 PM
