syncro question about the ex and dx tranny
i have a transmission from a ex and dx. i was wondering if the syncros from the 2 are the same. thanks
Re: syncro question about the ex and dx tranny
just put in in today. grinds 3rd. the guy i bought it off lied to me. it was only $80. so i wanna know if i can swap syncros out of my dx trans and put them into the ex.
how come a rebuild kit comes with new blocking rings and no new gears. they obviously must come off
Technically the blocker ring is supposed to be a matched item with its gear. That being said other than the way its worn, its more than likely not any different than the comparable ring in the other trans. Best suggestion is pull them apart and compare them. Using one form a different gear probably won't work quite as smoothly or last quite as long but I kinda doubt it makes a real big difference.
yea i just dont see the 3rd gear syncro in the dx being much different than the 3rd in the ex. i guess i'll just find out
it will be fine replace. you wont have any problems with it other then you will drop a few more rpm in that gear when you shift.
so your saying swap the gear with it too then? im going to run it through the calc real quick. it stilll wont be as long as the dx bc the final drive is different. i just dont have the cash for a rebuild kit right now since i just spent it all on new tires
you might as well try to match everything up the best you can. if the gears look good leave them alone, it would suck to put it back together and still have a problem though
Seagull Management
The syncros are the same between all '92 - '00 D-series trannys. 1st/2nd syncros are identical, 3rd/4th syncros are identical and 5th is an oddball. Odds are the 4th gear syncro out of the donor tranny will be in better shape than 3rd, both are the same, use whatever is in better shape. If you have a worn or damaged slider you can always rob it from the DX tranny as well.
ok thanks.on the trans website it says the rations of 2nd and 3rd are different.(others are the same) wouldnt that mean different size rings? anyone else know? also would throwing the 3rd gear from the dx help me at the track so i dont need to hit 4th?
Seagull Management
Nope, but something you could do is take a VX third gear and flip it around for 4th, giving you a very low 4th gear (its beed done before)
Joey Mitchell
04-29-2019 07:50 AM
96romaEK
07-29-2010 10:33 AM
EK45VTi
16
10-31-2004 03:05 AM
