swaybar options
Re: swaybar options
and how serious are you looking to go? for example, small like the Si's 13mm rear or large like an ITR 22mm rear, which will require further bracing.
Re: swaybar options
looking at options for both. so with the ITR rear, what kind of bracing is needed? i'm looking to start taking it to the track for some runs and maybe do a little auto xing.
Re: swaybar options
i like the ASR rear subframe brace, it adds a little ballerness to good function. Or you can go the ghetto fabulous way with washers for spacing and metal plates to spread out the load. If not, you will more than likely tear out your rear subframe.
Re: swaybar options
it will fit but i will need a asr frame brace and integra rear lower control arms. or after market. that what i have in my hb eg. works perfect
Re: swaybar options
http://www.jdmuniverse.com/forums/view_ekswaybars.html i used this thread to help me with my choices
Re: swaybar options
c1 sleeper, that was really helpful. Thanks. Looks like I'm just gonna look for an SI rear for now. Seems to be the best choice until I upgrade the front to a larger diameter.
