Swaybar Diameter????????
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: Swaybar Diameter???????? (Blue-Civic-Hybrid)
I think you can bolt on the 24mm GSR intregra bar instead,,but stock Si is 21mm i think...mm...
Re: Swaybar Diameter???????? (rodney)
correct. stock is 21mm. but, why on earth would you want a larger front sway bar? that would only worsen the understeer. get some nice bushings for the front and call it a day. get a big rear bar, that's the ticket.
Re: Swaybar Diameter???????? (DeceitfulCivic)
I agree, understeer sucks like a chestwound. I plan on adding Neuspeed poly bushings to my 22mm front bar, than adding the ST 19mm rear bar. Weeeee!!!!
New User
Re: Swaybar Diameter???????? (Spoon EJ)
if you look on the energysuspension website they say that the bars very. they say you need to measure them. it ranges from 19,21,22 i believe. although i am not positive. there could be slight differnces between models. such as the ex-a ex and si, there are other differnces so that could be where you flucktuation is in size.
at leasts the only thing that i could think of why they would be different
silverb18
19
04-23-2004 12:04 AM
TurboBumblBee
05-12-2003 08:39 PM
