Sway Bar Qustion
First off how thick is a EP3 rear sway bar and second is there anyway to make it fit a EG chassis with a integra rear brake conversion?
Re: Sway Bar Qustion
Originally Posted by Wakes4Fun
(Post 36870441)
Isn't the EP3 still running rear drum? If so, I can't imagine how the sway bar would bolt up to the trailing arm of an EG. I'd imagine the trailing arms are setup differently, especially since a ton of shit changed from the EK to the EP3. Why do you want to use an EP3 bar anyways?
why would you want to use an EP3? when the ITR's are readily available from any usdm/jdm parts dist. or even the dealership. i wouldn't mess with it, since you know that the DC2 stuff bolts right up. IMO
no it wont
All 94-01 Integra suspension will bolt up to all 92-95 Civic, except ITR. As long as the Civic originally had sway bars then it will bolt up. If it didn't, then you will just have to get the LCA's from the Integra and you are good to go.
If cost is an issue then definitely use Integra sways for your Civic. They can be had for cheap, and fitment is great. If you are looking for something stiffer then go with Eibach or Suspension Techniques. There is a thread that lists all the sway bar sizes for each trim. I do know that GSR's are the largest, give it a search. -XLR8 |
