Sway bar question
Sway bar question
Ok I got a rear sway bar today for my civic with all the end links I believe I have a integra rear sway bar, went to install it today an the angle ofthe mount to the lca was extreme. I kno I need civic mounts for it to work I looked at the si mounts an there different from my sway bar just curious how to make it work, if it matters I pulled it from a 94 civic sedan with a disk brake swap an the lca's had kind of a"s" bend to them so I'm guessing integra but don't kno what year they came from I hope I didn't waste my money an get the odd ball one lol
318 Curves, 11 miles
Re: Sway bar question
Take pics of the lower control arms, particularly the endlink mount areas.
Sure, include pics of the swaybar while you're there, but which swaybar you have doesn't really matter much. What matters more is which lower control arms you have, because that will determine which endlinks you need.
Generally, if you have integra or EG LCAs, you need integra or EG endlinks. If you have 96-00 Civic LCAs, you need 99-00 Si endlinks. If you have ITR LCAs, then you need ITR endlinks. Generally.
If you use the wrong endlinks for your LCAs, the geometry will be really weird.
Ok I took pics now I'm trying to get my password reset on photobucket so I can post them, an thanks vindicator I completely forgot to mention what lca's I have there the blox ones I got them cause I needed new ones bu mainly to run a sway bar thanks again guys
Well, I don't know if Blox makes different LCAs for EGs and EKs, I have them, and they're just like the 96-00 lcas, so I use 99-00 Si endlinks. Only difference with the blox and stock are the flashy looks and crappy quality.
Yea I've heard that blox ones are shitty but so far mine are good, do you have the si sway bar? Cause I've looked at that one an it's different then mine I'll post pics in a sec
ok heres my driver side mount
heres the passenger side
heres the endlinks on my sway bar
an heres the bar
hope this helps me get it installed on my car lol
an heres the bar
Those are integra/EG style endlinks.
Your Blox LCAs (I *think*) have endlink holes in the 99-00 Si location. Therefore, you'll need 99-00 style endlinks.
Blox makes a decent set of nonadjustable 99-00 endlinks that jhpusa sells for $35.
Sweet I'll look into them, they should work I hope cause I was lookin at a si swaybar an where the endlinks mount to it seems a Lil different then mine like it's narrower but I'll get them an give it a try thanks again an I do plan on gettin a thicker bar eventually
JMelt4
18
04-30-2007 07:43 PM
JDM_dreamer
01-08-2007 08:17 PM
