Swapping a Y8 into my DX. Which ECU?
Hey all.. I have a 99 DX hatch and im replacing the blown motor with a 98 spec Y8.
What exact ECU do I need?? I believe its P2P but I want to make sure first.
Thanks!! BTW does anyone know where I can get the oil pressure sensor? Thats on the VTEC solenoid?
Re: Swapping a Y8 into my DX. Which ECU?
Yep, Youll need a P2P in OBD2b which is 99-00. The ECU plugs are different on 96-98.
For the pressure switch, Try Ebay/ craigslist/ The Hondatech marketplace.
use the obd2b p2p u can get it from a eney 99-00 civic ex if ur useing the stock throttlebody with 3 wires thats the easyest or u can find a 99 civic si canadian with sohc vtec ecu i got one laying around ill let it go for cheep its for a 3 wire iacv so u just drop motor in swap throttle body and ur good to fgo just run 1 wire for vtec and loop the vtec pressure switch at the ecu plug and ur good to go ill sell u all the parts u need if u like ill even pin u a vtec wire so u just fish it threw the fire wall and plug it in to ecu jack and away u go i can also wire knock id do it just to get rid fo the code lol lol
ill sell u everythying u need for 150$ + shiping wires and plugs and ecu and instructions pm me if u want
your going to need to do the iacv mod. 3 -> 2 wire, and also wire for vtec, Just search on HT you'll find a DIY. and Yes, obd2b p2p, motor year doesnt matter, but accesories like Distributor, alternator, etc. need to be tranfered over from your blown motor (y7), as they utilize the obd2b plugs i.e.: Alt plug is square(obd2b) instead of round(obd2a) IF IM NOT MISTAKEN, double check me on that, im running off 12:30am memory and its been a long day. Do your research, it shouldnt be a terribly difficult swap. GL.
You can get an oil pressure switch here:
http://inlinefour.com/oembvtoilprs.html
Pretty sure all VTEC solenoids except K-series are identical, so this should work on any VTEC solenoid even though it says "B-series." To further back this up, I bought a VTEC solenoid gasket from the for a "B-series" and it fit the one on my D16Z6 just fine. Same part number and all.
You're probably better off buying used though for the oil pressure sensor. However, now you know you can use any of them as long as it's not K-series.
Thanks for all the helpful posts!
Oh okay thanks bro. Im already keeping an eye out for this.
Too expensive, ive been seeing some OBD2B ECU's for $40. I would love to get a sweet tune but no funds. :/
I need OBD2B Thanks though.
Im kinda lost bro but im really interested.
So you are saying that the Y7 TB is 3 wires, then how many is the Y8 TB? I already bolted it up, but I dont see what else I need on it.
I run the wire for the VTEC to the ECU, then the VTEC Pressure switch has a special plug for it on the ECU?
Thanks bro! Do I gotta splice two wires together?
Sweeet! Thanks man! Its HOP so my friend can probably get it chaeper for me. Im down to buy a used one though.
use the obd2b p2p u can get it from a eney 99-00 civic ex if ur using the stock throttle body with 3 wires thats the easiest or u can find a 99 civic si canadian with sohc vtec ecu i got one laying around ill let it go for cheep its for a 3 wire iacv so u just drop motor in swap throttle body and ur good to fgo just run 1 wire for vtec and loop the vtec pressure switch at the ecu plug and ur good to go ill sell u all the parts u need if u like ill even pin u a vtec wire so u just fish it threw the fire wall and plug it in to ecu jack and away u go i can also wire knock id do it just to get rid fo the code lol lol
ill sell u everything u need for 150$ + shiping wires and plugs and ecu and instructions pm me if u want
The shop where I bought the motor from gave me the VTEC oil switch. Thats $60 saved.
They also gave me the pulley, I dont think my D15B2 one will fit.
My friend gave me his IACV from his 2000HX, will it work?
And will a 5sp. 2000HX ECU work?
I finally got the motor in today but still not running.
What do I do about the whole throttle body issue? Do I have to have a Y8 TB?
Is my 99-00 DX harness plug and play, besides wiring the VTEC Oil switch and the VTEC solenoid?
Seagull Management
If its a 2 wire intake manifold mounted IACV then yes.
No, you want a '99 - '00 EX ECU
Yes
Yes.
You will need to obtain a '99 - '00 EX (P2P) ECU and preform the IACV fix and wire in vtec, both shown below.
Yes
I had a question on this subject. I bought a OBD2B to OBD1 Harness with a chipped P28 ECU. Will I still need to wire up the IACV 3>2 for the TB?
Newbie here.. I had a quick question relevant to this post.. I just got a 98 ek and I bought the Y8 head with a si manifold, should I go with the P28 or P2P ECU?? Is there any advantages or disadvantages.. Thanks
P2P ECU is plug and play, P28 requires a conversion harness
It came with the si manifold though.. I know about the wiring harness and all that, but is there any advantages of having the P28 over the P2P??
when i had problems with the IACV it just breathed funny at idle...started up no problem.
Don't just let the spare wire dangle. cover it somehow so it doesn't ground out against the firewall, i've blown a few fuses because of messy wiring.
I always used a P28 and it was easy as hell to socket. I either bought a chip or had a buddy burn one for me. I never used a P2P tho.
