swapping everything over from my DC to an EG....what harness to use?
EPIC TUNING
Aight Im stripping down an EG and putting my interior and b16 from my DC into it. Are the elec and engine harnesses seperate? I want to use the EX engine harness because it has vtec wired up, but I should use my LS elec harness so the dash plugs in no problem right? which harness does the cluster run off of? Im just not sure which harness to use.
so to sum it up.
1995 EX shell.....1994 Integra LS w/b16a donor car. what harnesses should I use? thanks.
so to sum it up.
Re: swapping everything over from my DC to an EG....what harness to use? (rewsnaeht)
interior harness is civic... (so cluster can work)
engine harness is integra... (its already on the b16)
-or-
engine harness from civic (since it has vtec)...
correct?
-or-
correct?
interior is plug n play, on the motor use all the parts that is in the integra like
mounts,linkage,complete motor w/tranny,ecu and yes use your harness. what year is your eg?? coz only 92 hb are prewired with vtec. so if yours is the latter years you will need to wire vtec to cabin harness
EF7
09-25-2006 09:06 AM
