swapping backwards (B16A6 - to - D16x).
Hi
I have a Del Sol 1996 with B16A6 in it.
My engine crankshaft pulley is broken, the key way is broking, the bolt is bend and the thread is worn out I am not able to find a crankshaft or a full engine.
So I made up my mind to change my engine and put a d16 engine which is available in the market.
I am not thinking of HP or racing I want to use it normally.
My question is?
Can I drop the d16 and use the b16 harness and transmission?
I know that I will not use the VTEC solenoid.
If i can do this swap what mounting I have to use?
And will the engine fit the transmission bolts?
I tried the search but no use no info in swapping in backwards.
Thanks in Advance.
My question is?
Thanks in Advance.
Re: swapping backwards (B16A6 - to - D16x). (DelSolMaker)
Thanks man
Ok what to do if I don’t want to spend more money and fix the problem.
And for some time I was thinking of B18x but I think it will be a double job.
So please advice.
Thanks
So please advice.
Thanks
Re: (serio_ENDLESS)
Ok if I go for a b18 or b20 as both of you said
What b20 I have to pick.
And do I have to change the harness and transmission in both case or no need and will the ECU fit in both engine or I have to change it.
Any links I can refer to for both b18 swap and b20.
Thanks
Re: (serio_ENDLESS)
Ok I will go with lsvtec but i don't have any on good in Honda in my area I live in U.A.E
So can you please explain for me how lsvtec looks like?
And on what car I will find it?
I will have to pull the engine from a car and what else I have to take else than the engine.
Keeping in mind I have a manual transmission
Is there any project I can look at so I can take a better idea?
Thanks
Thanks
Re: (serio_ENDLESS)
Thanks for the link
After reading the lsvetc setup guide I found my self unable to find most of the parts in my area so I will try this; finding a (B16Ax) in the internet or in any near country.
Can you please tell me what is the deference between (B16A6 and other B16Ax) engines?
If I can find a B16Ax will it fit in my car with no extra work and change?
I think it will be a drop in engine that’s all no need to touch any thing else right?
Thanks mate
Thanks mate
Re: (DelSolMaker)
dood! just buy a b18 or b16 longblock from ebay or on honda-tech...a b18 longblock will run you $300-$500...b16 around $800...this will save you a lot of headache. lsvtec can be a pain in the *** and can be much less reliable than a stock b16 or b18
KyonMechburg
08-03-2018 05:36 PM
crx04
08-27-2006 03:32 PM
