swapping B18A1 into 95 civic EX-HELP!
i am swapping a B18A1 from a 92 integra LS into my 95 civic ex (wasn't planned, destroyed d16 engine and had b18 in my garage with a rotted body). the engine assembly is in but now i'm looking for assistance with wiring it all together i put the b18 engine harness in along with the computer. all i have is key on power and nothing else.
Do i need to get a 95 integra engine harness, distributor and injectors? or just manully electrical pins in there connectors.
thanks for taking the time to help me
If you can't tell i'm new at this
Re: swapping B18A1 into 95 civic EX-HELP!
Ive done this before .You will need an obd1 intake from a 94-95 teg.Power steering brackets/and pump from a 3rd gen teg.You will need a 3rd gen cooling pipe with thermostat housing.You may get away with the ecu depending on the year on the 2nd gen.(not 100% sure).Theres some stuff you can get away with like alt i think.I know the starter will work.
Hope this helps some.What are you using a h/c adapter kit? or hydro trans with the a1 swap? I made my own adapter kit worked fine for me.
