swapping in b16a SIR I into civic
okay so i am swapping in a obd0 engine into a obd1 car. what parts off of a obd2 b16a or b16a2 do i need to make my car pass smog (emissions) test? would really like some insites becuz all that i can think of is just the intake manifold and the header plus 02 sensor. i think it needs more than jux two things right?
all advices are welcome.
Re: swapping in b16a SIR I into civic (DeathSquad)
p30 ecu, obd1 distributer.intake manifold, obd1 fuel injctors. obd1 TB...thats all i could thinkk of my head right now..might be more stuff?
Re: swapping in b16a SIR I into civic (jerryegk24)
thnx. and i was wondering would a gsr mani fit on the head and still pass smog? jw since i want more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeathSquad »</TD></TR><TR><TD CLASS="quote">thnx. and i was wondering would a gsr mani fit on the head and still pass smog? jw since i want more power.</TD></TR></TABLE>
intake or exhaust ? gsr intake manifold wont bolt on to b16a head and exhaust manifold will bolt on to b16a head but will not be driect bolt on to cat converter. cut and weld are required
Actually you wont be able to get it smogged or bar'd. You need to have the same year motor as the car or newer. Meaning if you have a 97 and your swapping in a 95 motor you cannot smog it. The motor has to be a 97 or newer to be smogged. Good luck!
