Swapped inner rails on DC2 seats, front bolt doesn't line up in EK
I bought a pair of DC2 seats to put in my 96 hatch and swapped the inner rails like I've read. The two bolts on the inner rails line up, and the rear bolt on the outer rails line up, but the front bolts on the outer rails are about 1/2 an inch away from the threads. Any insight as to why this is happening? I thought that you just had to swap the inner rails.
Re: Swapped inner rails on DC2 seats, front bolt doesn't line up in EK
It will fit you just gotta use a drift pin to line the last hole up, Dont tighten all the other three bolts down all the way until you have them all started a little.
Just swap both rails
Originally Posted by trustdestruction
(Post 40998058)
