swaping brake rotors
im in the middle of swaping my stock rotors for some slotted brembo rotors and have reached a problem, i think. after removing the brake caliper and the pad holder (i guess thats what u would call them) i removed the 2 screws that are in the middle of the rotor. as far as i know, my guess is those hold the rotor to the hub. now im trying to get the rotor off the car and i cant. what is left to do to get it off or do i just gotta work with the rotor to get it off. any suggestions would be great. thanks
Re: swaping brake rotors (persain488)
Most likely, it's rusted to the hub. This means you have two options: https://honda-tech.com/forums/images...es/emsmile.gif
1. Use a large hammer and start beating on the old rotor. Not recommended, and it's really noisy. 2. There should be a threaded hole drilled into the brake rotor's hat. I'm not sure what the thread pitch is (I want to say 10 x 1.50 - but don't quote me on that), but you should be able to screw a bolt down into that hole, and it will pop the rotor right off the hub. |
Just use a big hammer and slam the back of the rotor to getthe rotor off
karate kid kick ?
Re: swaping brake rotors (HamandEGgs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamandEGgs »</TD></TR><TR><TD CLASS="quote">Most likely, it's rusted to the hub. This means you have two options: https://honda-tech.com/forums/images...es/emsmile.gif
1. Use a large hammer and start beating on the old rotor. Not recommended, and it's really noisy. 2. There should be a threaded hole drilled into the brake rotor's hat. I'm not sure what the thread pitch is (I want to say 10 x 1.50 - but don't quote me on that), but you should be able to screw a bolt down into that hole, and it will pop the rotor right off the hub. </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif I think it's 10x1.25 at max. 1.5 is pretty course. Just grab one of the bolts that hold the brake line to the knuckle right behind the rotor and try those. I think those fit. Spray the crap out of it it with some PB blaster first and let it soak for like 2 minutes. Make sure your new pads & rotors aren't anywhere near it when you do that. |
You removed the caliper and caliper mount? The rotor should be loose after the screws are removed, beat it out, hehe.
Hint of advice: Dont reinstall the small screws so a future rotor replacement isnt a pain, the caliper will hold the rotor in place....... |
I had to shake mine pretty good for them to come off... just hit them with a rubber mallot front and back, top and bottom and they'll wiggle off.
bang on it
Re: swaping brake rotors (ruckussss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruckussss »</TD></TR><TR><TD CLASS="quote">bang on it</TD></TR></TABLE>
...With a rubber mallet. |
