Swap Wont Run
Swap Wont Run
I just finished my swap of a 98 GSR motor into a 96 Coupe. I used the stock harness from the 1.6 vtec motor, and extended wires as necessary. It started, so I shut it down and finished running all the coolant lines and added coolant. I went in restarted it, and then went to hit the gas and it died. It has not restarted since. It still cranks but just wont fire. There is spark and fuel. The crank is still lined up at top dead center as are the cam gears. It has skunk2 stage 2 cams, skunk2 intake manifold, rc 440cc injectors and hondata. Would could my problem be any help will be appreciated.
The only thing not wired up is the o2 sensor
Re: Swap Wont Run (B18c1EgHybrid)
I don't know dog, sorry to hear about that. There are some hoses that people normally miss. I would double check. If nothing else try stock parts to get it going then add in after market. You'll need that o2 censor, they're expensive though.
check and make sure the ecu is connected all the way.
i have that problem on my car, it just keeps turning over with fuel and spark. then i messed with the ecu wires (pressed them in hard as possible) and it turned on
Re: Swap Wont Run
Well the car ran and I didn't touch a thing, it idled twice like I said without a problem, so obviously the compression and timing were good. The ecu was not touched either, I mean I will check all this stuff, but is there anything possible to look for. The reason for the injectors is for nitrous down the road, once everything has broken in. Any other suggestions will be helpful thiank you.
Re: Swap Wont Run (pane93civhb)
Question about the cam gears they are pointing straight up at top dead center but on the side there is small circles with a line through them on each one are these supposed to line up also when the cam gears are at top dead center?
Re: (T25So)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T25So »</TD></TR><TR><TD CLASS="quote">Might wanna try the EK forum since you have an EK, not an EG </TD></TR></TABLE>
this is also the EK forum.
Re: (greenmonster)
I just talk to skunk2 and they said that I might have jumped a tooth and to check that, is that possible? Also with the tps, it won't start up again though. Thats the only thing that gets me and leads me to believe what skunk2 says might be right.
Moderator
Re: (T25So)
are you series??? you know how similar if not exactly alike the 2 cars are???
Moderator
Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">check to see if you got the tps and map plug got switched.</TD></TR></TABLE>
it will still start and run and drive....like *** but it will still start...
Re: (ALL DRiVER)
Well I ran the codes and got a code for crank position sensor, (I have the obdII to obdI harness from skunk2). So would that cause the car not start? Wondering if the sensor is bad and which one it is because I have an obdI distributor that I could take the sensor out of, its an ls so I don't want to cut the leg and put it on the car I would rather switch out the sensor, A Picture Would Be Nice, if possible.
Re: (jay.dee.em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 »</TD></TR><TR><TD CLASS="quote">why do u have such large injectors for that setup??? </TD></TR></TABLE>
ya, the injector are way to big, its gonna run really rich. But ya, cheack all the grounds, and if the timing belt jumped a tooth, it would still run, but it would run like **** and not be very safe either with skunk 2's, might bend a valve.
Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">are you series??? you know how similar if not exactly alike the 2 cars are???</TD></TR></TABLE>
not to be a dick but there is quite a difference in 0bd1 and obd2....
Re: (T25So)
you might want to try reading the title of this form EG+ Civic and stop bein a n00bster..
as for the swap, sorry to hear about it and i thinkn everybody here has covered what i would have said.
Team Bassick Alpine
29
12-03-2011 02:59 PM
FlewByU352
05-14-2010 07:23 AM
