Swap, Throttle cable question.
1 Post
Ok im in the final stages of the swap but i cant figure out the throttle cable thing. Should I be using a GSR cable or should I somehow be able to use my civic one?
96 b18c int 2k civic hx.
If this is for the stock gsr tb and manifold. You can use the civic cable, but you'll have to add about a 1/2 inch of washers on the two bolts that holds the bracket.
If you have a skunk2 manifold. You can use the 99 si cable and bracket.
import-tooner
01-25-2011 05:30 AM
boomersz
16
03-10-2007 08:08 PM
gsrboy18
10-11-2005 11:52 AM
