Swap question...any help??
So i have a 93 civic coupe with an h22 swap in it...if i get the headers will it align with my catback or will i need to customize it???
Unceasing Measure
Re: Swap question...any help?? (H22CIVICJDM)
It will align just fine, but the length will undoubtedly be off. K-Teller makes an adjustable pipe that you can use to remedy this or you can have a local shop cut and reweld it.
Re: (THEDirtyDseriesWOOT)
oh ok so witch headers would be good. the ones that came with the car are custum and they hang so low their like a cm from the floor and the car is just decently dropped
Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Oem header with a 2.5" collector will be better than any header you buy for less than $600</TD></TR></TABLE>
are you saying it would be a waste of money to buy some knock off headers in the meantime??....i plan to go boost but i dont wanan waste that much on some headers if they are going to be replaced later on. the set up it has now is the oem header and the bottom looks custom but its a shitty job it bends to low to the ground its not to close to the oil pan but the ground.
Ek Forever y0!
Re: (H22CIVICJDM)
Yes, i am saying it is a waste of money to buy a cheap header.
headers aren't THAT beneficial until you start buying headers that have some R&D behind them. I.E. Headers that cost $500+
Re: (H22CIVICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CIVICJDM »</TD></TR><TR><TD CLASS="quote">Ok how about some DC headers those go for about 300 are those a waste too??</TD></TR></TABLE>
Yes.
Yes.
Re: (Syndacate)
so witch ones then?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Yes.</TD></TR></TABLE>
Re: (H22CIVICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CIVICJDM »</TD></TR><TR><TD CLASS="quote">so witch ones then?</TD></TR></TABLE>
Get a JDM H22A header or a Toda header - it's all how much $ you put into it.
Throw some DC Sports header on it - it's fine - it's just a negligible difference on a DC Sports header opposed to some ebay header in terms of 4 cylinder naturally aspirated engines.
Re: (Syndacate)
jea i mean 300 is not bad but i just figured why waste 600 on some headers when i plan to boost the car later on......i just need something temp i hate the way headers scrape the floor and its barely that low
X2BOARD
40
05-27-2009 09:15 PM
