Swap Help.
Guest
Posts: n/a
Swap Help.
Need to know what engine harness will i need to put in a 96-00 cx to put a GSR swap. also does the linkage out of a Si or LS integra fit too. i know the GSR does.
Any websites that will help me i wanna get a OBD-1 Swap in it. OBD-2 will be the last resort. also its going to be JDM engine B18C.
I
I
Re: Swap Help. (StreetRacnGsR)
Stick with the same OBD as your chassis. If you're doing it yourself, you'll save about 2-4 weeks worth of wiring just by staying OBD2, and thats provided you have access to software with extensive wiring diagrams for both vehicles (your chassis and the car your donor engine is coming from) such as AllData. As far as the shift linkage, just go with the integra linkage.If you stay OBD2, you will only need to add one wire to your existing wiring harness, and thats your VTEC wire that needs to be run from the new ecu, your harness you have now will plug up as is. If you have more questions, feel free to post again.
NZDelsoldude
09-22-2014 08:35 AM
