Swap Ek sedan b20b/gsr w/ls 5th
Okay so I have a 99 ek sedan, trying to do my homework on swapping to a b20b. I have most of it figured out, so I think.
PARTS
b20b
intake manifold (integra ls)
Motor mounts (online kit)
ecu (obd1 p75 w/jumper)
Gsr transmission
gsr clutch
ls 5th gear
shift linkage ?
shifter ?
axes ?
throttle body ?
throttle cable ?
harness ?
distributer ?
exhaust manifold ?
what am I missing? anything with a question mark I'm unsure about. oh and subframe......stock ek or do I need somthing else?
PARTS
b20b
Gsr transmission
gsr clutch
ls 5th gear
shift linkage ?
shifter ?
axes ?
throttle body ?
throttle cable ?
harness ?
distributer ?
exhaust manifold ?
-Intl Steve Krew
Re: Swap Ek sedan b20b/gsr w/ls 5th
PARTS
b20b
ecu (obd1 p75 w/jumper) ((run an obd2b P75))
Gsr transmission
gsr clutch
ls 5th gear(use gsr, it's fine for hwy driving)
shift linkage ? (Integra or EM1)
shifter ? (Same as linkage)
axes ? (Integra / B series, depends on the intermediate shaft)
throttle body ? (LS)
throttle cable ? (EM1)
harness ? (Use your stock harness, just do the research to extend a couple of sensor plugs)
distributer ? (LS)
exhaust manifold ?(whatever B series header you prefer)
PARTS
b20b
Gsr transmission
gsr clutch
distributer ? (LS)
You'll need a cat convertor or test pipe
Use a stock Integra clutch (oem exedy replacement or the like)
why not? I'm currently driving a b20 ek coupe and 80 on the highway at 3500-3700. I drive about 130 miles round trip a day. I have read that ls 5th will bring the rpm's down to about 3k which would save some gas, and not be so harsh on the motor
You really think a 500rpm change with the same throttle position is going to save gas? 3.5k on the highway isnt gonna kill the motor at the slightest bit. If anything it will assure It's properly warmed up before shut off.
Not to mention you are sacrificing your 4th-5th powerband.
I mean **** if you have the time and feel like ******* around in the tranny go for it but it isn't going to save you gas, I'd be much more concerned with adding a LSD, to really put ALL of the power to the ground.
ALLMOT0REJ1
Northeast (Sales)
03-22-2010 09:15 AM
SivikHatch
12
07-31-2004 09:53 AM
WangChung
30
10-16-2003 09:16 PM
