swap economy question
ok,i am once again considering getting a swap in my 5th gen civic. my car is not wired for vtec and has abs. i would like to know what would my best bang for the dollar as far as the swap is concerned. i would like to add to the price that i will need a vtec wiring harness and more like then not axles from a car with abs. oh and dont forget the maintenance items.
Re: swap economy question (nijia555)
Turbo to be honest with you. D series motors can be quick as long as you don't plan on breaking into the 10s and just want a reliable street car with some power.
d's are a better bang for your buck than b's
turbo it and you'll be faster than gsr swap
get good at driving (w/o hitting boost) and you maintain good mpg
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">d's are a better bang for your buck than b's
get good at driving (w/o hitting boost) and you maintain good mpg</TD></TR></TABLE>
Hell, I boost regularly and still see 30+ MPG.
Re: (middleman)
i considered turbo, my current engine is in bad shape. so it will need to be swapped out. i was under the impression that turbo will require more maintanence that a swap. i am not as mechanically inclinded as i thought i was, i recently had to get my car towed after trying to fix something myself. more likely than not someone else will be doing the install
Re: (middleman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by middleman »</TD></TR><TR><TD CLASS="quote">turbo is expensive when you start blowing engines.</TD></TR></TABLE>
Turbo a D series (1.6 prefered, VTEC or non-VTEC) w/ 4-7 PSI, keep up with fluid changes. You won't blow an engine.
Re: (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">
Turbo a D series (1.6 prefered, VTEC or non-VTEC) w/ 4-7 PSI, keep up with fluid changes. You won't blow an engine.</TD></TR></TABLE>
Yep, maintence is the key. You can find another motor like you have and do a turbo setup for less than a B series swap.
Re: swap economy question (Mista Bone)
can't beat a turbo d16z6 for a cheap-fast honda. I can't belive how fun it is messing with marrows and stangs. my swap and turbo was about a grand. it's really fun.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">Z6 swap, runs low 13's on the bottle, get 42 mpg on the highway. Even on the Penn. Turnpike!</TD></TR></TABLE>
42 MPG? yea maybe coasting down hill... those #'s are bogus
Re: swap economy question (middleman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by middleman »</TD></TR><TR><TD CLASS="quote">what kind of HP gains do you get running 4 psi?</TD></TR></TABLE>
I belive its 40hp gain.
Thats what it is with the GReddy kit. Set at 4 psi. No BOV, or FMIC....not required.
Re: swap economy question (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">
42 MPG? yea maybe coasting down hill... those #'s are bogus</TD></TR></TABLE>
Mista Bone is one of the brightest here knowing D series, along with Spade. I'd take his word any day!
D Tranny Guru
those numbers are just as bogus as Bisi running 10's on a NA SOHC CRX 1530 cc motor.
I'll ask one question.........Can you TUNE????
Well, can you??????
Must I also add I'm running 325 cc/min injectors also?
I went 440 miles on 9.9 gallons of gas, it was a personal best after 7 years of owning the car. Then refilled when I got home at same station I filled at for accuracy. 360 miles on 8.8 gallons.
800 miles on 18.7 gallons of gas = 42.78 mpg
Can YOU TUNE??
WELL, can you??????
Right now I'm at 300 miles since last fillup, fuel gauge is at 1/2 mark. Which as any 5g owner knows is really 1/3 tank.
People just have to hate those that can run a good number and tune a car for mpg.
Many can tune for hp.
Many can tune for mpg.
Very few can tune for both!
Well, can you??????
Can YOU TUNE??
WELL, can you??????
research before speaking.
i used to run 13.3@103mph with my B18C and still get 40mpg. all motor/all on 91 octane, and all interior present.
current setup JDM D15B: 37L of gas gets me about 600km on tank which is about 45mpg.
1997civicEXd15vtec
13
07-06-2007 11:50 AM
