SWAP IS COMPLETE, ONE FINAL QUESTION....BATTERY TERMINAL/FUSE BOX HOOKUP!
Hey guys, swap its done Finally! My final question is on my EG the stock harness looks like it only has 2 positive lines that goes to the fuse box. On my OBD2 GSR harness, it looks like there is 3?!
Where does the extra 3rd one hook up to?
I started it up and the car ran fine, its just I have that extra positive plug coming from the battery terminal that I DON'T KNOW WHERE IT GOES!!
Also about the IAB, should I cut the wire at the selenoid plug and run it DIRECTLY to A17? Or should I just switch pin A20 to A17 at the ECU like a lot of people have said, then wire the black/yellow plug at the IAB to a positive 12v+ hot source and be done with it?
Re: SWAP IS COMPLETE, ONE FINAL QUESTION....BATTERY TERMINAL/FUSE BOX HOOKUP! (Revolution2zz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolution2zz »</TD></TR><TR><TD CLASS="quote">I started it up and the car ran fine</TD></TR></TABLE>
then cut the extra thing comming off the battery and call it a day
For some reason I want to say that is the power cable for the ABS system, but I can't remember for sure... Sorry, I'm not much help...
Re: SWAP IS COMPLETE, ONE FINAL QUESTION....BATTERY TERMINAL/FUSE BOX HOOKUP! (makibaka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makibaka »</TD></TR><TR><TD CLASS="quote">For some reason I want to say that is the power cable for the ABS system, but I can't remember for sure... Sorry, I'm not much help...</TD></TR></TABLE>
Yep, the teg's with ABS have that cable running to the abs fuse box.
Re: SWAP IS COMPLETE, ONE FINAL QUESTION....BATTERY TERMINAL/FUSE BOX HOOKUP! (JDMH22HATCH)
yes the third power cable you dont need. just remove it from the wiring harness you will be ok
Re: SWAP IS COMPLETE, ONE FINAL QUESTION....BATTERY TERMINAL/FUSE BOX HOOKUP! (NextelBuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy »</TD></TR><TR><TD CLASS="quote">yes the third power cable you dont need. just remove it from the wiring harness you will be ok</TD></TR></TABLE>
ditto great to see the swap is done.. lets see some more pics
DailyDriven259
05-11-2012 11:31 AM
mugenEJ1_777
05-29-2010 02:36 PM
