swap in 95 eg power steering problem
im putting a ls/vtec in my 95 eg coupe. I know the d series PS mounts wont work so i have b series and I see the d series pump wont work either because where yo tighten the belt up doesn not bolt up with the b series mounts. so i got a gsr PS pump and the PS hose comming from the PS rack wont bolt to the PS pump. I dont know what to do. Has anyone come accross this problem or know what to do about it???? thanks.
Re: swap in 95 eg power steering problem (BOOSTEDgreeneg)
sounds like someone ripped u off for a different PS pump. it should work. i did a swap a month ago and the line from a 94 civic ex bolted right up to the gsr PS pump
Re: swap in 95 eg power steering problem (fmrprojects)
yea i have the right brackets and the pump says p72 right on it. did a gsr ps pump change in style at all over the years? because the the hose that bolts to the pump the holes dont line up and the there is like a dowl pin on the hose to seal in the hole on the pump that is to small?
Flite
12-05-2006 02:59 PM
