suspension setup
suspension setup
Ok i got a 93 hb dx im puttin a ls motor in around spring i wanted to know what a good suspension setup would be. What kind of springs/shocks combos are you guys using and do you like them? Sway bars, should i get gsr or itr or something else. I live in ct and the roads are not in good condition there actually quite horrible so i need something that doesn't have a rough ride.
I saw tokico shocks/springs (blue) on ebay 310$ seemed like a pretty good deal but i dont know if there any good. Also should i go with adjustable shocks?
thank you for any help you can give I like to hear peoples personal experience rather than people tryin to sell you somethin thank you
Re: (hybrid93SIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid93SIvic »</TD></TR><TR><TD CLASS="quote">that's what H-T is here for </TD></TR></TABLE>
Re: suspension setup (B18C5_EK)
B18C5_EK = im runnin APEXi N1's, comptech rear lower, Spoon rear strut. works for me
Thats a SWEET setup what did that cost you?? did you lower it and need a chamber kit too?
Re: suspension setup (slntciv)
i agree...save up and buy the tein RE's..comes with adjustable coilovers, shocks, and upper pillar ball mounts. even tho they may be a grip...they are well worth the investment. tanabe sustec pros or jic magics are also awesome.
Re: suspension setup (RamiroM)
HKS hypermax 2 coilovers
HKS pillow ball mounts
JDM ITR rear lca's
cusco OS front & rear strut bar
GSR front sway
ITR rear sway
Beaks kit
Spoon rear tie bar
C pillar bar.....
get one peice coilovers...worth every penny....and nothing like else like em
JDM ITR rear lca's
GSR front sway
ITR rear sway
Beaks kit
Spoon rear tie bar
C pillar bar.....
Re: suspension setup (tibbor)
i'm running tein ss coilovers. they give a nice balance of ride comfort and good handling. i guarantee the roads where i drive are much worse than where you are, and i get around just fine. get some adjustable dampers, with conservative spring rates (nothing too hard), si front antisway bar, comptech rear antisway / tie bar combo. <- this thing kicks ***. and some inexpensive strut bars, and maybe poly bushings too, if you don't mind sacrificing too much comfort..
those of you with neuspeed race springs and kyb's what size rubbers are you using? and also did you buy the race made for your car or made for integs? i know that you can fit dc2 suspension on ek's for sure but i dont know about da's and egs
Pooping on children
Re: suspension setup (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">gc's w/ custom rates, koni yellows, 21 or 24mm front bar, 22mm comptech rear sway/tie.</TD></TR></TABLE>if you dont already have one id invest in a beaks kit also its good stuff
Re: suspension setup (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">if you dont already have one id invest in a beaks kit also its good stuff</TD></TR></TABLE>
thats the beauty of the comptech piece... absolutely no need for a beaks kit. it will not tear out of your subframe... well, it will if it manages to tear through 10mm of billet aluminum first. i love this damn thing.
Re: suspension setup (jwn7)
what do you guys think about koni yellows and ground control coilovers for an eg. My car will be a daily driver and autocross car. I think the whole system runs under 1000.00 and i really dont want to spend more then 1400 what sytems can compare? thanks in advance
Re: suspension setup (teamsol)
if you'd do a search you'd realize that more than half of the "serious" guys on this board use the koni/gc set-up because it kicks ***.
Si Arn
03-15-2003 03:36 PM
-K3-
08-20-2002 06:22 PM
