Suspension reccomendation
Im looking to change out my suspension for something a little less rough on my 94 Si. Im currently running Koni yellows with KG/MM DR21 suspersport springs. Can anyone reccomend anything softer that still handles decent?
Re: Suspension reccomendation (POS Hatchback)
You may want to look into getting some Type-R springs. I have them on my car. It lowers it about 1.5 inches. The ride is fine and it is stiff enough to never bottom out. If you plan on getting the ITR shocks then you will need rear lower arms off an ITR.
I went with the full upgrade springs/shocks, used $300. Arms were a total of $80.
Good luck
Good luck
Eibach Sportlines are decent.
Too soft for me but maybe perfect for you.
Ground Control can set up some specific rate coilovers for you ya know, call 'em up.
