Suspe...
Suspe...
ive been reading quite a few things concerning suspension relating to negative cambers and stuff and i have a question now. im planning to do a KYB AGX shocks with eibach prokit springs, will i need to buy camber kits? lower control arms?
and one more question, is the KYB/eibach combo good for DD and lowering the car a bit?(enough to get rid of wheel gap) ive read a lot about them but not enough info on DD or how they look on a EK(ej)... thankss in advance, i appreciate it
Re: Suspe... (xquiksilvazx)
if u want to get rid of wheel gap u betta go with coilovers.....i had KYB AGX with skunk2 lowering springs and the drop wasnt too much. and if u tryin to drop it more than 2 inches then yea u need a camber kit.
with the AGX and prokit springs im not 100% possitive but i dont think that will eliminate wheel gap. As for a camber kit, anything lower then 2inchs usually you will want to run one (others will tell you just to have your toe set correctly, im tucking and have a skunk2 front kit and no camber wear). For LCAs most civics dont have the sway bar hole. unless you want to run a sway bar (if you dont have one already) there pretty much just a bling kinda factor. Ive got the Ksports and will be running a sway bar when im not lazy. looks awesome under the car. If you have any other questions feel free to Pm me.
cool thanks for all the replies, i think im gonna stick with the kyb agx/eibach prokit, maybe down the line ill get some LCA's haha thanks for the info
b18c5go
11-23-2002 11:55 AM
