sunroof wont open or close
i've just replaced my driver side door and now the sunroof is not working. I don't know what is wrong. I've checked all the fuses and everything seems to be ok. can anyone tell what it could be?
Re: sunroof wont open or close
well it seems it has worked b4 u replaced the door so apparently something was not put back together when u finished. id just go back and look for any wires that need put in its place. or if u forgot anything.
i have the same problem. my sunroof isn't working at all after i replaced my driver side door. i have a 96 civic ex coupe. i've checked and re-checked all the problems that are clear to me. like checking all the wiring and fuses. could it be the relay? there's also another problem that i came across after replacing-- my lock isn't working either. please reply ASAP!!!!!!
i replaced my door in a 99 a while back, the sunroof wouldnt work after you used the power locks, kept popping a fuse under the hood. It was for the sunroof and locks if i remember correctly, strange i know, but took it back to the shop and they had to use my 99 harness since they thought the harness that came with the door would work but nope
what does "CONNECT THE nO.1 TERMINAL TO BODY GROUND WITH A JUMPER WIRE" MEAN?
what is BODY GROUND? is that the medal part of the car? And what is Jump Wire??
corpsebesideme
07-02-2014 08:07 PM
slammed4dreg
12-27-2008 01:07 AM
model x
Audio / Security / Video
07-25-2003 06:02 PM
