Subframe removal/swap step by step
1 Post
Hopefully noone else has the need to do this but in case you do heres a step by step on the removal and changeover process. I had the weld break that holds the bolt that keeps the controll arm attached to the subframe. car was making a rattle over bumps and stuff so I check only to find the the bolt has worked itslef 3/4 of the way out and with a little wiggling could be pulled in and pushed out at will. Scared me. So here you go. You might find it interesting if anything. By yourlsef if you are handy with tools you should be able to finish in about 8 hours stopping only once for a hotdog and some mac & cheese. enjoy.
http://repo.jackmoves.com/view_album.php?page=1
