Stupid question but....
New User
Re: Stupid question but.... (jdmcivicferio)
It's probably different in the '92+ but in our '91, we used a very versitile tool called 'excessive force'. It is now forever a 2-seater.
Re: Stupid question but.... (A)
Re: Stupid question but.... (MADEinJAPAN)
ummm there is one bolt you have to take out that is in the middle of the seat (by the seat belt connector"!!! you need to push down from the top (in the middle)of the seat to see it! then there is 2 L shaped clips on both sides of the seat that you need to push towards the back of the car! hope this helps
Re: Stupid question but.... (5ZigenSol)
I know that in the hatches, there are two black clips on the pole that runs through the back supports. They just push back (rotate back) and pull off. After you do this, you can push the back supports towards the side of the car from the middle divider. It should slide right out of the slot in the middle. There is then one bolt to that holds the bottom section down. Pull the bottom part up from the back and then slide it up. Tadah!
FotoGenetix
04-26-2007 01:51 AM
